identify this part
identify this part
This came out of a 1997 LX 4 door auto. The key was repeatedly getting stuck in the ignition. I had someone come and open up the column / ignition. They removed this part, now everything is working fine. What is it? It was located underneath the steering wheel towards the top of the column I believe. The rod went into the silver object, and the silver object was housed in the white object.
Re: identify this part
No idea what it's called, but it's on the bottom of the column. While sitting in the driver's seat, it's at the 6 o'clock position on the column, just to the left of the key hole. At least on a 5th gen Civic. It just locks the column from turning.
H-T White Ops
I wish I actually knew where this was on the column.
I think it sort of looks like a piece that goes on the underside of the ignition switch, but I could be wrong.
H-T White Ops
Okay, well, I messed with that on my '88 CRX because I needed to replace the ignition switch harness and it was the key in reminder.
If you leave your car off, put the key in the ignition and open the door, does a buzzer go off?
bscottclarrk
01-02-2012 02:50 PM
EvenStar
02-23-2007 08:36 AM
