trouble with axles
trouble with axles
ok i have taken the axle nut offi have taken the cotter pin and nut off the lower control arm but it wont budge from the strut!! any suggestions?
Re: trouble with axles
I fear hammer damage. Instead I use the recommended ball joint separating tool:
https://honda-tech.com/forums/showpo...2&postcount=20
I've also separated ball joints with a Pitman tool. If you have the proper sized tool, it works fine, though sometimes the inward pointing tabs are too thick to fit under the ball joint boot.
sony224422
07-07-2007 03:29 PM
