mirror install
1 Post
Re: mirror install
what part of the install do you need help on? taking off the old mirrors? wiring? or putting new mirrors on? were there any instructions that came with it?
Re: mirror install
Typically open the door look at orig mirror, on the inside should be a plastic cover, should pop off, and there will be screws, take them out, and pull off orig mirror. I am wondering do the new ones have the same mounting locations?
1 Post
Re: mirror install
follow motegicivics instructions. pretty basic, and no you dont have to take off the battery.
i thought you had the wrong mirrors and wanted to make them fit.
Re: mirror install
new ones are suppost to fit haha. and after taking the triangle thing on the inside off i cant get at the 2 lower screws... i can get the top one. gotta take off the door pannel???
Re: mirror install
dont need a video man... take the plasic cover off and door panel and remove the 3 screws(i believe) and bam the mirror pops rights out
to take the door panel off there is a
1. plastic rivet on the top right side of door panel
2. a screw in the coin holder
3. a screw that holds the plactic door handle cover on
4. and pull the door panel from the bottom and slide it up
Ronny Claudio
Honda CR-V & Element
01-31-2019 07:19 PM
