GM Syncromesh or GM Syncromesh Friction modified?
i got a 3rd gear grind , anything above 2500 rpm,
before i do any major tranny work, i want to try that miracle GM syncromesh fluid eveyrone is talking about.
i know they don't sell the Friction modified anymore, but i thinki know where to get some.
Is it better to get the Friction modified one or just the reg GM synchromesh?
thx :D
thx :D
Seagull Management
Re: GM Syncromesh or GM Syncromesh Friction modified?
friction modified is supposed to be the stuff. Be aware the grind is going to come back and it's going to cost more to fix it later depending on what's wrong with it now.
I think gm discontinued the one with friction modifier they sell a tiny bottle of friction modifier for around $12 or Get a low mileage tranny @ HMO for $250 autozone sells Pennzoil syncromesh and trans x friction modifier as well I've used both oem and pensoil
hows that pennzoil syncromesh working? heard its similar to the GM one. also if i get the trans x friction modifier do i juss mix the penzoil and the trans x together?
The gm seems to work better I've used the Ford and gm modifiers I have to run that trans x cause of my clutch style LSD and yes you mix the additive with the synchromesh if you can afford it run the GM
Car was stolen today in west covina
https://honda-tech.com/forums/southern-california-87/stolen-civic-ek-coupe-socal-west-covina-2968535/
Jowee
05-15-2005 01:11 PM
1.8
23
10-03-2004 03:32 PM
Sketch_hs
11
02-23-2004 04:37 PM
12377916, 1992, 2011, automatic, discontinued, find, friction, gm, honda, modifer, modified, penzoil, synchrmesh, synchromesh, syncromesh
