Throttle body gasket dor D15B
I just want to make sure I'm getting the right part, my block is stamped D15b (not D15b7 or D15b8), I have a z6 head and an intake that I'm pretty sure came off of the D15b engine (it doesn't have the port for the evap purge solenoid valve).
While I'm at it, where should I hook up my evap purge solenoid valve? I have the electrical connection, I have the tubing (currently stopped up with a screw), I just don't have anywhere to plug it into on the intake.
Thanks all!
Thanks all!
PHANTOM MENACE
Re: Throttle body gasket dor D15B
Any of the 92-95 DX/LX/EX/Si throttle body gaskets should work. To be sure though, double check the back of your manifold near where that purge solenoid should be mounted. It should be stamped P08 if it's the D15B VTEC manifold (I believe that's correct anyway). If so, a Z6 gasket will be the way to go. For the solenoid, tap the mounting stub and mount it. For the vacuum connection you can T off an existing vacuum line.
Yep, it's got the P08. Does the gasket that Advanced Auto Parts carry work ok? It's here: http://shop.advanceautoparts.com/web..._478106014____
Also, can I 'T' into the fuel pressure regulator (as it's the closest vacuum line), or should I try and find another line that isn't as critical a component to tap into?
xotic_crx
12-22-2014 07:47 PM
1boostedcivic
12-29-2003 10:56 AM
