main relay part #
main relay part #
I just picked up a main relay from honda for a 93 lx 4dr. Theres the part # on the bag which is:39400-s10-003. But the part number on the relay is rz-0159. The original is
rz-0132. Any problem with this? I've had trouble with the same retard on parts before, but never got a wrong part yet.
Re: main relay part # (Doctor Zagato)
Did you see if the female (plug part) on the relay matches the old one and would plug into the harness? I know that when I bought a replacement, the part was physically larger and a little different bracket but it bolted up and the harness connected fine. They said it was the revamped part that has better solders and larger space to vent heat etc.... some of the problems the old one incurred.
I try not to determine by wether it just fits or not, although it seems to work that way. I found out on a parts store online that either will fit, bc they will send u either.
Yea i figured that it was like a redesigned part, since the hot weather seems to fry these suckers.
