B16A
B16A
power problems on B16A all simple stuff checked plugs,wires,timing,cams,cam gears
could it be my knock sensor some friends of mine think it could be retarding the timing???
Re: B16A (93SIRII)
in my experience the knock sensor doesn't actually do anything to help your engine in case of knocking or in your case the knock sensor mal functioning. so it is prolly is something else. what makes you think your down on power?
Re: B16A (tek_civic)
did u check all the vacuum lines. i have never had a problem with the swap since i havent done it but i have heard many a people on the board have the same problem and the vacuum lines werent right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic »</TD></TR><TR><TD CLASS="quote">in my experience the knock sensor doesn't actually do anything to help your engine in case of knocking or in your case the knock sensor mal functioning. so it is prolly is something else. what makes you think your down on power?</TD></TR></TABLE>
I call BS. The knock sensors purpose is to detect detonation. If it detects any detonation, it retards the timing and runs in "safe" mode. So it stands to reason that if the KS is defective it could affect performance.
Someone else back me up.
Re: B16A (hatchdrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchdrvr »</TD></TR><TR><TD CLASS="quote">
Someone else back me up.</TD></TR></TABLE>
That's what I would imagine.
Make sure your MAP and TPS are not switched (same plug and very close), mine were for a day and it felt like a slug, switched em back and it was like new.
Re: B16A (93SIRII)
Have you changed out the fuel pump yet. I just did on my b16 swap and it helped a bit on my 1/4 mile times, eventhough they still suck due to a bad driver.
Re: B16A (93SIRII)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93SIRII »</TD></TR><TR><TD CLASS="quote">it only makes 140whp thats crap.</TD></TR></TABLE>
if u are saying that it makes 140 without any other mods done too it then thats about right. it has 160 at the flywheel. so with the appropriate drive train loss 140 is ballpark
93(Civic)EG6
09-28-2006 01:43 AM
ek_b16
01-04-2005 10:41 PM
