civic with b18c runs great until it warms up.. then bogs like a motha... my friend has searched long
Old 08-26-2003, 09:15 PM
djay86's Avatar
Default civic b18c runs great until warmed up.. Bogging like Crazy! Someone come here and help figure out wh
Alright.. This post is for a friend.
Basically at initial startup, whenever the engine is completely cold, it runs like a champ... Probably for about 5-15 minutes. Once the engine warms up, it bogs.. sputters.. misfires... and runs like ****. You pull the plugs after it running shitty and the bitches are ghost white.. indicating its running lean. It really sounds like a fuel problem.. either the injectors or the ecu is bad possibly?
THe car is a 1997 Civic DX
it has a obd1 jdm b18c with p72
polished intake manifold
brand new rotor and cap
new walbro fuel pump
FPR and FPG set at 55
header
new spark plugs
http://www.imagestation.com/pi...8.mpg
djay86 is offline
Old 08-26-2003, 09:21 PM
B_CRUZ!'s Avatar
Default Re: civic b18c runs great until warmed up.. Bogging like Crazy! Someone come here and help figure ou
does the ecu look for a knock sensor? is it hooked up? did you try using a stock fuel regulator?
B_CRUZ! is offline
Old 08-26-2003, 09:31 PM
tour de france turbo's Avatar
hey he posted this for me. everything is a yes except for the fuel regulator. that wouldnt cause it to do this would it?
Modified by stock ek sleeper at 12:41 AM 8/27/2003
tour de france turbo is offline
Old 08-26-2003, 10:26 PM
madman604's Avatar
55 psi seems high. try 40-42 psi
madman604 is offline
Old 08-26-2003, 11:06 PM
u2civic1's Avatar
Default Re: (Turbo E)
55 is way too high stock setting are like 40
u don't even need the high flow fuel pump
u2civic1 is offline
Old 08-27-2003, 02:56 AM
Default Re: (u2civic1)
the car is already running to lean, with it set that low it hardly runs
Old 08-27-2003, 03:58 AM
white99gsr's Avatar
Default Re: (stock ek sleeper)
O2 Sensor
white99gsr is offline
Old 08-27-2003, 05:47 AM
1990hondaHF's Avatar
Default Re: (white99gsr)
Have you ever heard of "heat soak"? It's when hot air is sucked up into the intake and the mian sighn of this is "bogging" when accelerating. I had it all the time with my Contour....just an idea.
1990hondaHF is offline
Old 08-27-2003, 05:50 AM
smnowell's Avatar
Default Re: (1990hondaHF)
Yeah, I have sort of the same problem. Not as bad as you are discribing yours to be, but I am pretty sure mine is a cause of heat soak... I don't know what to do to overcome this, but if anyone has ideas, post them up.
smnowell is offline
Old 08-27-2003, 06:21 AM
SpyderZEX's Avatar
Default Re: (b16a ferio)
Will heat soak turn your car into a COMPLETE DOG? I have this same problem and I highly doubt that it is heat soak. Heat soak will only kill a few hp, not destroy your power curve.
SpyderZEX is offline
Old 08-27-2003, 09:50 AM
Phink's Avatar
this sounds like the exact same thing thats happening to my car....93 hatch with OBDI GSR engine....haven't checked my plugs yet, but i've went over the wiring bout 50 times, checked all the sensors, new cap, rotor, plug wires....fuel pressure is set to bout 45psi.....i'm gonna check the plugs and see if a new ECU could help...you may wanna try that.
Phink is offline
Old 08-27-2003, 10:33 AM
djay86's Avatar
Default Re: (darkb18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkb18c1 &raquo;</TD></TR><TR><TD CLASS="quote">this sounds like the exact same thing thats happening to my car....93 hatch with OBDI GSR engine....haven't checked my plugs yet, but i've went over the wiring bout 50 times, checked all the sensors, new cap, rotor, plug wires....fuel pressure is set to bout 45psi.....i'm gonna check the plugs and see if a new ECU could help...you may wanna try that.</TD></TR></TABLE>
Yes, This is my friends car.. I believe he told me about you having the same problem as him. We just finally got a video of it, so people can actually see whats going on.
I do not believe its heat soak? If it was, there would be way more similar problems.. We've tried a few diff o2 sensors, checked wiring and a few other things..
We're waiting for a new p72.. my question is.. Can an ecu make your car act crazy like that?
djay86 is offline
Old 08-27-2003, 11:09 AM
porsche997dc2's Avatar
Default Re: (djay86)
Are the plugs ghost white for all 4? Check for voltage at the fuel pump. Change back to a good stock fuel pump.
porsche997dc2 is offline
Old 08-27-2003, 11:21 AM
BLK JDM's Avatar
Default Re: (porsche997)
I don't think you need the Walbro pump. I had problems with mine. Change back to a GSR pump. It may be heat soak but I think you're getting a lil too much fuel.
And how do you know the car is running lean????
BLK JDM is offline
Old 08-27-2003, 11:28 AM
Default Re: (jigga008_99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jigga008_99 &raquo;</TD></TR><TR><TD CLASS="quote"> how do you know the car is running lean????</TD></TR></TABLE>
Look at spark plug. If it turns white then it's running lean. It should be light brownish.
Old 08-27-2003, 12:07 PM
SpyderZEX's Avatar
What kind of plugs is he using?
Old 08-27-2003, 12:36 PM
SpyderZEX's Avatar
Default Re: (hatch22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch22 &raquo;</TD></TR><TR><TD CLASS="quote">note to self dont buy a obd1 gsr engine</TD></TR></TABLE>
Yeah, that was funny. Noob
Old 08-27-2003, 01:48 PM
Default Re: (SpyderZEX)
there NGK plugs, forget what kind but they were about 10 a plug. i took them out and all 4 are as white as my ***. the fuel pump was replaced cause the stock one was not holding pressure. after installing it, it fixed the fuel pressure problem. i need some seriouse help guys this is a MAJOR problem and is affecting my daily life
Old 08-27-2003, 02:48 PM
fu*kfaceC1EH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch22 &raquo;</TD></TR><TR><TD CLASS="quote">note to self dont buy a obd1 gsr engine</TD></TR></TABLE> go ahead and note that ya ********. obd1 b18c1 in my 95 hatch. couldn't have asked for a better running motor and easy swap. hatch22, you should do the h22 swap. it's real easy and guaranteed to never have ANY problems when swapped.
fu*kfaceC1EH2 is offline
Old 08-27-2003, 02:53 PM
poison's Avatar
You are running way rich for 1, and two, sounds like a faulty O2 sensor if that doesn't solve the problem.
poison is offline
Old 08-27-2003, 03:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">You are running way rich for 1, and two, sounds like a faulty O2 sensor if that doesn't solve the problem.
it cant be running to rich, when i pull out the plugs there white as hell.
Old 08-27-2003, 04:03 PM
its a B&M FPR. how would it make it heat soak? what causes this gay heat soak?
Old 08-27-2003, 05:40 PM
djay86's Avatar
Ok guys.. its an obd1 gsr engine.. who cares... lets stay on topic here.. Me and my friend are trying to figure out his problem...
1. Having the fuel set at 55 would NOT cause the problem.
2. Can an ECU go bad?
djay86 is offline
Old 08-27-2003, 05:54 PM
HavokB18's Avatar
I had the EXACT same problem with my GSR. Turned out to be an interittant resistance issue in my plug wire. replaced plugwire and it runs fine.
HavokB18 is offline
Old 08-27-2003, 05:57 PM
SpyderZEX's Avatar
Yes an ECU can go bad, but that is a pretty expensive problem to fix. You are going to be better off checking the less expensive stuff first. It sounds like you guys have tried almost everything. I was going to suggest changing the fuel filter, but I can't remember if you guys already did that or not. If you have checked the entire fuel and emissions system, and found nothing, then I'd start looking at the ECU. I would deffinately drop the fuel pressure back to somewhere around 40psi. A higher fp can affect your mixture in more ways than one. If the psi's are too high they will make it harder for the actuator in the injector to move the pintle, thus at higher RPM's it won't have as much time to open. Therefore you will misfire, bog, and lean out your mixture.
Somebody please correct me if I'm wrong, but I'm pretty sure this could possibly be the case. So turning down the fuel pressure might be worth your while.
Quick Reply: civic with b18c runs great until it warms up.. then bogs like a motha... my friend has searched long
