FUEL PRESSURE PROBLEM
EG b18c1 swap, cams, p&p, other mods.. Car is idling at around 50psi and the WOT is at 25-30psi! Car is running like crap. Anything ? I NEED HELP! Thanks
The fuel pressure is low, that's the problem... Which vacuum lines do I check? Also, it wasn't doing that before I changed the fuel filter (pulsing that is.).
Re: FUEL PRESSURE PROBLEM (93preludeh22)
I HAVE THE SAME PROBLEM IN MY CIVIC...
JACKSON SUPERCHARGER
THE JACKSON FPR WONT TURN IT DOWN PAST 50PSI! INSTALLED A VORTECH FPR... SAME PROBLEM! PLEASE HELP!!!!
im running a 255lph, b&m fpr and guage. im running 50psi with the hose off, pinched. it was at 45, and i was running lean. it dips to about 40 when i open the throttle wide. runs fine
