hybrid b16 a/c bracket + compressor '92 si
? hybrid b16 a/c bracket + compressor '92 si
Ever since my b16 (del sol dohc) engine was fitted.
I have not been able to use my stock
D16 a/c bracket.
I heard I can use the dohc del sol bracket but
That is $ 98 online.
I was hoping I could use possibly
A gsr or type r
A/c compressor and bracket
(since my compressor is REALLY old)
Which bracket can I use on my 92 si?
A) del sol dohc
B) gsr/ type r
C) fug it since I live in SF. Ha
*I love honda-tech.com*
D16 a/c bracket.
A gsr or type r
A) del sol dohc
B) gsr/ type r
Re: hybrid b16 a/c bracket + compressor '92 si (97itr86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97itr86 »</TD></TR><TR><TD CLASS="quote">I believe any B-series one will work not sure.</TD></TR></TABLE>
Same here. If it has a stamp "P54", then for sure it fits. I have the p54 ac bracket that went into 3 different size engine. Check my signature.
Re: ? hybrid b16 a/c bracket + compressor '92 si (tvr.blu.eg6^)
you need a p54 delsol vtec ac bracket or use a jdm itr aluminum(slightly modified) to make your ac comp work with your b16.
if you use a gsr ac bracket only one bolt will light up.
another option is to use a jdm b20 aluminum ac bracket(i have one available if you need one) the top two bolts will line up.
Re: ? hybrid b16 a/c bracket + compressor '92 si (eg6si)
any b series will fit, but only the del sol a/c bracket will allow you to use your compressor, which has to be your stock compressor.
Re: hybrid b16 a/c bracket + compressor '92 si (porsche997)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porsche997 »</TD></TR><TR><TD CLASS="quote">
Same here. If it has a stamp "P54", then for sure it fits. I have the p54 ac bracket that went into 3 different size engine. </TD></TR></TABLE>
90jdmcrxdude
01-09-2007 12:46 PM
wizzards581
03-08-2004 09:27 PM
