Someone please HELP!!!! D16y8 in 92 hatch dies on freeway and wont start back up.
I was cruising my hatch down the highway in traffic this morning and I pushed in the clutch and the car just died. It made no odd sounds and has no check engine codes. I checked for both spark and fuel and I am getting neither. I dont know what the hell. I kinda think it could be the main relay but I am a prior EF owner and dont know where this is located on a 92+. If anyone has any Ideas please let me know. I am up for any Ideas because I dont know where to start. Thanks.
Re: Someone please HELP!!!! D16y8 in 92 hatch dies on freeway and wont start back up. (civicdragger
The relay and some fuse are by the battery. It's a black box.
if ur not getting, both spark and fuel then its most likely your MAIN RELAY, located by the driver kick panel right below the handle to open the hood. If it doesnt click when the u put the key on the on position then thats your problem. Its a big brown relay with a brown plug. It could also be the ground wire on the thermostat housing is LOOSE cause it provides the Ground for the main relay. If the ground is good then open the relay up and inspect for broken Solders, if solders are good try cleaning it out with like a brake cleaner or some other cleaner cause sometimes it sticks. But you will still have to replace it cause thats just a TEMP FIX.
Just2Bar
05-19-2015 03:59 PM
