Turn signal question
Turn signals are not working at all! bulbs won't go on as well as the turn signal light on the cluster won't blink. What can be the problem? any suggestions would greatly be appreciated.
Re: Turn signal question (Luserkid)
i have had this happen before, my hazards fried a fuse, but i wasnt aware of it, until a friend of mine raced someone in it and tried to hazard light them and left the switch on, with the switch on and a blown fuse the turn signals won't work
Re: Turn signal question (Ming Tsai [foodtv])
Check the both bulbs, check fuses, Check the flasher relay that is pluged into you fuse box. Did you take the plastic around the ignition off? I had this same problem, I checked everything and even replaced my flasher relay. It ended up being the harness where it plugs into the turn signal arm.
goodluck
goodluck
