Damage to CAI in wheel well hole
has anyone else had and problems with a hole be cut into you CAI at the part where it enters the hole to go into the wheel well?. My Mechanic said that it happens sometimes after a long period of the pipe restin on the edges of the hole.
Re: Damage to CAI in wheel well hole (RacerXI)
ok cool. I had just got some work done to my car and got a new intake so when i saw the old one I was like WTF because i was planning on selling it or using it again in the future.
Re: Damage to CAI in wheel well hole (BLK99VTECR)
What I did was take about a foot of rubber hose (black) either 1/2" or 5/8" and cut it down the center of the hose on the outside of the coil. Then you press it in very similar to the window seal around the edge of the hole. It will keep it from hitting the metal.
Re: Damage to CAI in wheel well hole (-TRINiTRON-)
yea I had planned on doing that same thing for over 6 months and never got around to doing it. Im just surprised that all those times i was hearing it rattle its was cutting such a big hole in the pipe.
I noticed it rattling when I first put it in, so I put the hose in there later that week. It has been in for two years and there is only a dull spot in the paint on the CAI.
Re: (hondasport2000)
Not to jack the thread...I had a similar problem. The edge of the air filter was rubbing on a hardline for the clutch and had worn a hole in it. (Found out after the fact). I was coming off my exit and my clutch pedal stayed depressed. Luckily I was able to coast down the hill to my garage. Tried to JB weld it but ended up replacing the hard line.
Just had to vent
Just had to vent
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -TRINiTRON- »</TD></TR><TR><TD CLASS="quote">What I did was take about a foot of rubber hose (black) either 1/2" or 5/8" and cut it down the center of the hose on the outside of the coil. Then you press it in very similar to the window seal around the edge of the hole. It will keep it from hitting the metal.</TD></TR></TABLE>
thats what I did
thats what I did
MyYellowHonda
06-25-2002 07:00 PM
Quik89Si
10
04-19-2002 11:36 PM
