HELP!! What Do I Need??
Can someone tell me what all I need off of here? I need help ASAP!. I need a rear motor mount of a SI. This pic of off http://www.hondaautomotiveparts.com from a '99-'00 Civic Si. I need to know everything I need.
I have a '99 Civic Hatchback. Please help. Thanks
Re: HELP!! What Do I Need?? (Nameless EJ6)
I am buying a B18C complete swap. Comes with all motor mounts. But someone told me I had to get some sort of mount of an SI. Is that all i need? #7?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless EJ6 »</TD></TR><TR><TD CLASS="quote">you need number 7
EDIT: number 7 is a bracket. Which is used for a B series swap..
If you want the "mount" that's number 3...</TD></TR></TABLE>
yup......u need 7 but u dont need number 3.....its on the car
Re: (ransack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ransack »</TD></TR><TR><TD CLASS="quote">#7 The rear tranny mount
#A-5-20 (the piece that connects below #4) Its the lower driver side engine mount. You do need this mount</TD></TR></TABLE>
Are you sure? about the #A-5-20
Re: (JDM CTR EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR EK »</TD></TR><TR><TD CLASS="quote">
Are you sure? about the #A-5-20</TD></TR></TABLE>
I dont know if thats the number, but you do need that lower mount
Re: (JDM CTR EK)
Yes you do need that drivers side bracket that bolts to the block. There's a weird number on there.. I'd call the dealership and check on that one before you order it.
Re: HELP!! What Do I Need?? (eg cookiemonster)
here you go..these are all the si mounts you need...buy em from hparts.com, they're a few dollars cheaper than hondaautomotive...
Rear Tranny mount from the 99-00 Si: 50827-S04-N10 $28.86
Driver side mount bracket from the 99-00 Si: 11910-P30-000 $40.12
96 del Sol AC bracket: 38930-P54-000 $94.82 ( only if you want to keep your ac)
Re: HELP!! What Do I Need?? (JDM CTR EK)
You need the Si drivers side upper mount bracket, Si rear bracket, lower tranny bracket (extends out to tranny) and if your looking to use AC just buy a 96-97 delsol Vtec AC bracket and use your stock civic ac condenser (bolts right on)
Re: HELP!! What Do I Need?? (pennies_hatchie)
Rear Tranny mount from the 99-00 Si: 50827-S04-N10 $28.86 Got It!
96 del Sol AC bracket: 38930-P54-000 $94.82 ( only if you want to keep your ac) Got It!
Driver side mount bracket 11910-P30-000, that would be the A-5-20 piece in the picture?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR EK »</TD></TR><TR><TD CLASS="quote">Driver side mount bracket 11910-P30-000, that would be the A-5-20 piece in the picture? </TD></TR></TABLE>
sounds right, just make sure its the lower mount that bolts into the engine
asocallocal
04-11-2008 10:28 PM
Capsule Kid
16
02-01-2008 06:48 AM
fowler!
20
04-27-2003 05:30 PM
