Is this good compression??
official honda whore
let it crank some more untill it stops going up.... then if there still low pour a lil oil (capful) into each cyl when your going to check it and if it goes up alot higher then you have probs with your rings
Re: Is this good compression?? (GPoodle)
Was the motor warmed up before the compression test? They don't differ a lot from cylinder to cylinder which is good, but they do seem low..
I tested my brother's 1st gen XSi B16A when I put the engine in, and it was 200-210 in all cylinders. Of course the motor was from an automatic car, so I doubt it was abused much. The CRX VTEC helm supplement says:
nominal: 185 psi
min: 135 psi
max. variation: 28 psi
Should be the same as your 2nd gen motor. So at least you're still in spec...
nominal: 185 psi
min: 135 psi
Guest
Posts: n/a
Thanks for the prompt replys guys =D
The car was warmed up and I cranked it until the compression tester stopped jumping around on the valve cover (like i said, maybe 3-4 cranks)...
So the numbers are low, that sucks. Does less compression mean less HP?
Also, Im reading the c-speedracing guide, and they say it is "very important that you press the gas pedal to the floor". Makes sense since I did it with just the clutch in... >_<
They did a test on an 11.6:1 motor and got 250psi, but their B18C1 yeilded 185.
I'll try it again tomarrow and see if the results are any different.
Thanks again,
-Jonah
Thanks again,
-Jonah
Re: (GPoodle)
i believe you should let it crank like 7 or 8 times. thats what the crappy haynes manual said to do. make sure its at normal operating temp, and yes it does make a difference if you are at wide open throttle or not. try it again and see what happens...
Convert
01-28-2009 05:44 PM
Powered by VTEC
02-03-2008 08:36 PM
