Starting problems with a EG6 B16
well, a few months ago a did my swamp in my EG6 witha B16A and I put a "new" canadian distributor and everything went fine until afew months later when my car car wouldn't start and i waited afew minutes and started right up,did the same thing one more time but the 3rd time the car died and wouldn't start, then I changed the ignition coil and the car started right up but only for a few weeks, then died again and again I changed the ignition coil and the car started right up and someone told me to change the ignitor too so I did and I change the ignition coil and the ignitor but after a few weeks the car dies again and I had to change the ignition coil to start the car again. what is the problem with this? do i have to change the main relay? I checked the main relay but it looks ok...should I look something in particular in the main relay? or should i change the distributor?
Modified by Carlos_E_Zero at 4:19 PM 9/29/2003
Modified by Carlos_E_Zero at 4:20 PM 9/29/2003
