Need some HElp with Swap
My friend has a 99 Civic HB
He just bought a 2000 ODB2 GSR swap that he wants to put into his EK
Will the Rear Integra Mount work ??
Also will the GSR harness work with the ek ???
He also has an OBD2 GSR ecu - will that work ?
and will all the other mounts work ??
please let me know, what he needs to do this swap
Re: Need some HElp with Swap (muzikant25)
the rear integra mount will not work (try civic SI) and do a search for the other mounts (hybridgarage.com TECH) as far as the harness should work as well as the ecu but I would have a OBD1 jumper and ECU on hand to make the swap easier if you are in a crush for time
hey im not sure about the harness stuff, but im almost posotive that the ecu and harnasses will wire right up with no problem, u might have to run a knock sensor wire and vtec wires if his car is not currently Vtec. but his car is obd2 so the new ecu and harness should work fine. the motor is a usdm motor right? if its JDM then u will need to take the harness off his current motor and put it on the other one
Re: Need some HElp with Swap (oneslodx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslodx »</TD></TR><TR><TD CLASS="quote">u might have to run a knock sensor wire and vtec wires</TD></TR></TABLE>
good luck.
good luck.
Re: Need some HElp with Swap (ITRacer121)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRacer121 »</TD></TR><TR><TD CLASS="quote">I would have a OBD1 jumper and ECU on hand to make the swap easier if you are in a crush for time</TD></TR></TABLE>
why would he need that, both the vehicle and engine are obd2b?
Civ-dx-96
10
02-28-2013 04:15 PM
pr_tony_montana
02-03-2005 05:13 AM
