removing air conditioning?
Hi can someone please help, ive looked around and i cant find it so i was just wondering how to remove the entire air conditioning unit from my 1995 civic ex coupe, but the tricky thing is, is that its turbo so i dont have that much room to work with so if some one can tell me and easy way to do it it would be greatly appreciated.
Re: removing air conditioning? (turbocivic95)
That sucks, you should have done it before you had your turbo installed, because their is no room to spare in that engine compartment. To get the AC off you're going to have to pull it forward to get it off the brackets, so you might have to unbolt your downpipe and possible your exhaust manifold
You can just do this.. take out the compressor first and also take out the lines to the condensor and the Evaporator. From there you will have some room to move the condensor and the condensor fan. Make sure you remove the fan from the condensor for a easy removal.
travmantravis
10-20-2007 05:00 PM
dingusjt
11-13-2003 02:10 PM
