Del Sol Short Shifter
Old 08-09-2004, 11:59 AM
Del Souless's Avatar
Default Del Sol Short Shifter
I am thinking of buying a Skunk2 short shifter, probably the Dual Bend one. What im worried about is that the length of the shifter, I saw this one video online and it was an after market shifter that was ALOT higher than the stock shifter in a del sol. I juss want some insight on this cuz i like my shifter at least stock high but prefferably lower.
Del Souless is offline
Old 08-09-2004, 02:22 PM
Default Re: Del Sol Short Shifter (delvic)
anybody????
Old 08-09-2004, 02:55 PM
TSPeed Factory
AzntaggeR's Avatar
it probably had a civic or integra shifter in it, because those sit a little taller then stock del sol shifters.
AzntaggeR is offline
Old 08-09-2004, 03:13 PM
bigjon06's Avatar
I have a 1993 Del Sol and I was wanting to do an engine upgrade what should I get?
bigjon06 is offline
Old 08-09-2004, 03:49 PM
duh blacksheep's Avatar
Default Re: Del Sol Short Shifter (bigjon06)
i bought a civic shifter for my del sol and it was just as tall as stock
duh blacksheep is offline
Old 08-09-2004, 03:52 PM
just grab it lower down the shaft when you shift for racing...
MNEJ2GUY is offline
Old 08-09-2004, 04:42 PM
Dave421's Avatar
Default Re: Del Sol Short Shifter (MNEJ2GUY)
ok, a short shifter isn't meant to necessarily be shorter in height than stock. it's meant to shorten the throw. it's a lever.... what really matters is how much longer it is below the bushing (under the car). having a shifter that sits down in the boot does less than something stock height with a longer axis (like the skunk2)
Dave421 is offline
Old 08-09-2004, 04:54 PM
revvin9k's Avatar
Default Re: Del Sol Short Shifter (Dave421)
I have the dual bend Skunk for my Sol and it sits very high almost as if it were meant for a Civic, i'm getting rid of mine. Had a DC before but bearing split so I grabbed the Skunk one and am not pleased. Might get the single bend. Just my thoughts.
revvin9k is offline
Old 08-09-2004, 06:18 PM
nocturnaldragon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigjon06 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1993 Del Sol and I was wanting to do an engine upgrade what should I get?
First off stop trying to jack this thread do a ******* search this has been covered so many times i cant begine to count!
As for the short shifter i have a single bend one and it works just fine, dosent hit the exhaust in the least and sits pretty comfortable. It came with the car so i dont know what a stock one would sit but id imagine it would be right around the same.
nocturnaldragon is offline
Old 08-09-2004, 06:52 PM
GorData's Avatar
Dont Put a integra Shifter of any kind in your Delsol Cause it will be Super Long, I just did that last summer and boy was I upset when the Shifter looked like one of those brand New Si.
GorData is offline
Old 08-09-2004, 09:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave421 &raquo;</TD></TR><TR><TD CLASS="quote">ok, a short shifter isn't meant to necessarily be shorter in height than stock. it's meant to shorten the throw. it's a lever.... what really matters is how much longer it is below the bushing (under the car). having a shifter that sits down in the boot does less than something stock height with a longer axis (like the skunk2)</TD></TR></TABLE>
I realize that it isnt meant to be shorter, its juss that im more comofortable grabbing low than somthing hella long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S(J)O(D)L(M) &raquo;</TD></TR><TR><TD CLASS="quote">I have the dual bend Skunk for my Sol and it sits very high almost as if it were meant for a Civic, i'm getting rid of mine. Had a DC before but bearing split so I grabbed the Skunk one and am not pleased. Might get the single bend. Just my thoughts.</TD></TR></TABLE>
Thanks for the advice on getting a single bend cuz I was still unsure which would be better........
And thanks for all the help guys
To bigjon06 start ur own post man geez.............
Skip01
09-13-2009 06:07 PM
colnago
05-19-2009 04:50 AM
powerdbygarrett
08-25-2007 04:57 PM
scrap1ngsr
04-04-2005 10:31 AM
tweekerz
01-17-2005 06:26 PM
Quick Reply: Del Sol Short Shifter
  • Ask a Question
Question Title:
Description:
