Weird problem with JDM EG city lights
Old 08-08-2004, 06:13 PM
Dangydang's Avatar
Default Weird problem with JDM EG city lights
I'm not sure if this is normal or if something is just wrong with the reflectors in my headlights, but when the city lights are on, the passenger side is a lot dimmer than the driver side. I know it's not the bulbs since I replaced both sides with fresh bulbs. Does anyone else have this problem? Here are some comparison pics I snapped:
Driver Side:
Passenger Side:
Chad, if you see this, thanks again for the help
Dangydang is offline
Old 08-08-2004, 06:15 PM
Darth ModerVader
Padawan's Avatar
Default Re: Weird problem with JDM EG city lights (Dangydang)
Have you double-checked all of your wiring? Also, are you sure that each of the sockets is seating properly? It almost looks as if the focal points of the two bulbs are different inside the lenses, causing one to appear brighter.
Modified by Padawan at 10:53 PM 8/8/2004
Padawan is offline
Old 08-08-2004, 06:16 PM
Dangydang's Avatar
Default Re: Weird problem with JDM EG city lights (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Have you double-checked all of your wiring? </TD></TR></TABLE>
Yeah, all wiring is correct. It seems like the problem lies in the reflector.
Old 08-08-2004, 11:21 PM
bonta-kun's Avatar
bump im having the same problem but mine are oppisite
bonta-kun is offline
Old 08-08-2004, 11:27 PM
I have the exact same problem with mine , but I tired new bulbs, aligned the lights, triple checked the wiring and it was still the same.......... I am guessing the reflectors inside the housing is different or it could be the angle that your looking at your head lights
RELprojects is offline
Old 08-08-2004, 11:40 PM
JDMGSR EG's Avatar
im pretty sure its the reflector because my old ones were like that and then i got projectors and hated them so i traded some guy for stock and now both are bright. good luck. DUNDADA!!!!!!!!!
JDMGSR EG is offline
Old 08-08-2004, 11:45 PM
99CivicExCoupe's Avatar
Default Re: Weird problem with JDM EG city lights (JDMGSR EG)
try switchin the entire kit on both sides to check ur reflectors
99CivicExCoupe is offline
Old 08-09-2004, 12:01 AM
bonta-kun's Avatar
Default Re: Weird problem with JDM EG city lights (99CivicExCoupe)
ohhh does anyone know how to make the corner lights turn off when u turn on the headlights so that they only come on when you blink
Old 08-09-2004, 12:32 AM
dampachi's Avatar
Default Re: Weird problem with JDM EG city lights (bonta-kun)
mine do that on my jdm headlights also.. i think its the focal points as people already said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonta-kun &raquo;</TD></TR><TR><TD CLASS="quote">ohhh does anyone know how to make the corner lights turn off when u turn on the headlights so that they only come on when you blink </TD></TR></TABLE>
you disconnect the red/yellow wire from the corner light to make it off and only on when you turn on the turn signals/hazards.
dampachi is offline
Old 08-09-2004, 03:26 AM
(teh)H2OUUP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dangydang &raquo;</TD></TR><TR><TD CLASS="quote">
<FONT COLOR="pink">Chad, if you see this, thanks again for the help </FONT> </TD></TR></TABLE>
NP, Good Buddy !!!! We should try eliminating the corner lamps to see how they would look....looks good I am bothered by the dim side light too.....
(teh)H2OUUP2 is offline
Old 08-09-2004, 03:38 AM
Default Re: Weird problem with JDM EG city lights (H2ouup2)
<FONT COLOR="blue">Here you go I dug up some old pixors, and it looks the same passenger side is dimmer......</FONT>
Old 08-09-2004, 06:40 AM
Dangydang's Avatar
Woah Chad! Secret, forgotten pixors of your caaah...wasn't ready for that I guess this is normal though since others are having the same problems.
Cian Mcloughlin
08-13-2012 12:06 PM
Bthasht
03-27-2009 08:35 PM
smores
02-16-2006 05:23 PM
jdmh22luda
07-14-2005 08:41 AM
Dangydang
08-11-2004 02:24 PM
Quick Reply: Weird problem with JDM EG city lights
  • Ask a Question
Question Title:
Description:
