Ex Tranny
Old 08-09-2004, 10:18 AM
StRacer's Avatar
Default Ex Tranny
Has anyone actually put an ex tranny on a dx(hatch) and noticed a bid difference?
StRacer is offline
Old 08-09-2004, 10:20 AM
Electrician
Deemeetree's Avatar
Anyone and everyone who has placed an EX/Si D16Z6/D16Y8 transmission on a platform that has the CX/VX/DX/LX transmission has noticed a big difference in acceleration and shorter 1/4 mile times.
Deemeetree is offline
Old 08-09-2004, 11:35 AM
StRacer's Avatar
Default Re: (Dimi)
I found one at the local junkyard, but it is out of an vtec-e. Is there a difference?
StRacer is offline
Old 08-09-2004, 11:38 AM
Default Re: (StRacer)
Between that and the ex tranny? Yes
Revolver is offline
Old 08-09-2004, 11:40 AM
murmur9's Avatar
Default Re: (Revolver)
get the d16y8 SOHC VTEC tranny ...it has the shortest gears i believe of all d series trannys....vtec-e is for the HX or CX i believe...dont get the vtec -e
murmur9 is offline
Old 08-09-2004, 11:51 AM
StRacer's Avatar
Default Re: (murmur9)
Thanks for the info. I will look for one. Is $300 a good deal.
StRacer is offline
Old 08-09-2004, 12:03 PM
senpai's Avatar
how many miles? what year?
senpai is offline
StRacer's Avatar
Default Re: (maztur)
51k 96+
StRacer is offline
Old 08-09-2004, 12:09 PM
Soccerking3000's Avatar
thats not that bad if, i would try to lower it a bit and see if you could maybe save 25-40 bucks more, also if it still has fluid in it drain it before you buy it and see if it has metal shavings in it, if it does dont get it it was raped in its past life
Soccerking3000 is offline
Old 08-09-2004, 12:17 PM
senpai's Avatar
Default Re: (Soccerking3000)
Yea, I'd try to lower the price more, but I'm cheap
senpai is offline
Old 08-09-2004, 12:29 PM
Electrician
Deemeetree's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murmur9 &raquo;</TD></TR><TR><TD CLASS="quote">get the d16y8 SOHC VTEC tranny ...it has the shortest gears i believe of all d series trannys....vtec-e is for the HX or CX i believe...dont get the vtec -e </TD></TR></TABLE>
No.
Same gear ratio of the D16Z6 tranny. Only difference is that the shift forks are a lot stronger than the D16Z6 ones.
The VTEC-E transmission is a VERY long geared transmission. Worse than the DX/LX transmissions. The VTEC-E transmission is shared with the CX platform. Since the VTEC-E is out of a VX, don't get it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StRacer &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info. I will look for one. Is $300 a good deal.</TD></TR></TABLE>
If it is in good condition, the most I'd pay is $200-$250 MAXIMUM. If it has been raped, $100. But you won't really know if the Synchros are good until you install it.
Old 08-09-2004, 12:48 PM
Marauder's Avatar
Yes, expect to pay about $700 from a salvage yard for a Y8 trans in good shape.
Most good used ones go for $250 on H-T
I bought a used one for $150 and told it was good, but when I took it apart, the first few gears were fried!
Marauder is offline
Old 08-09-2004, 01:25 PM
antiJDM's Avatar
Default Re: (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">
I bought a used one for $150 and told it was good, but when I took it apart, the first few gears were fried!</TD></TR></TABLE>
are you kidding me..i could find them all day long for cheaper than 700 at a salvage yard
antiJDM is offline
Old 08-09-2004, 01:27 PM
Marauder's Avatar
Default Re: (2thousandcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic &raquo;</TD></TR><TR><TD CLASS="quote"> are you kidding me..i could find them all day long for cheaper than 700 at a salvage yard</TD></TR></TABLE>
Depends on supply at the salvage yard. When I was looking, it was hard to find one, so prices were higher. If they have too many in stock, then its cheaper.
Marauder is offline
Old 08-09-2004, 02:24 PM
StRacer's Avatar
K, I have never done a tranny swap b4. All i need to swap an ex tranny to a dx is a ex clutch, correct?
StRacer is offline
Old 08-09-2004, 02:32 PM
Electrician
Deemeetree's Avatar
From other threads, it seems that the pressure plate, clutch and flywheel will bolt right up. No need to get an EX pressure plate, clutch or flywheel.
Should be a straight plug and play procedure.
Anyone want to concur?
Old 08-09-2004, 03:14 PM
antiJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StRacer &raquo;</TD></TR><TR><TD CLASS="quote">K, I have never done a tranny swap b4. All i need to swap an ex tranny to a dx is a ex clutch, correct?</TD></TR></TABLE>
nah..all you need is a flathead screwdriver, 3/8"socket wrench, 10mm socket, 12mm socket, 14mm socket, 1/2" socket wrench, 17mm socket, 1 1/8" socket (i think) for your axles, something to press your shift linkage pin out..be aware, its aka "bitch pin" and make sure to bleed your slave cylinder when you're done..
i also have a friend that has a sohc act clutch he bought but hes selling his car..it'd be a good investment since you're going to have everything apart.
antiJDM is offline
Old 08-09-2004, 05:18 PM
senpai's Avatar
The axle nut is 32mm (metric please!)
Also, inspect the throwout bearing, pilot bearing, and flywheel (you might want to resurface it)
senpai is offline
Old 08-09-2004, 07:42 PM
antiJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur &raquo;</TD></TR><TR><TD CLASS="quote">The axle nut is 32mm (metric please!)
Also, inspect the throwout bearing, pilot bearing, and flywheel (you might want to resurface it)</TD></TR></TABLE>
ha sorry..i always use the standard socket, im too broke to afford a new socket hahah
antiJDM is offline
Old 08-09-2004, 07:43 PM
Risky Business
BauleyCivic's Avatar
you dont have to take off the axle nuts to take the trans off!
BauleyCivic is offline
javon972
07-11-2008 05:40 PM
Purple_Civic
06-17-2005 07:10 AM
.Beaver
06-12-2005 09:36 AM
IMOTEPHT94501
07-09-2004 11:21 AM
b18cEK
14
02-10-2004 02:06 PM
Quick Reply: Ex Tranny
  • Ask a Question
Question Title:
Description:
