KYB AGX questions
KYB AGX questions
Getting all four of em done and im strongly leaning toward AGXs. Cars a daily driver, not slammed. Looking for a non-bone jarring ride and good handling. I hear theyre bad a on bumps? Good choice for daily driver? I searched and read the preferred settings and some install tips, but just want a quickie on your guys' experiences. TIA for feedback.
Re: KYB AGX questions (JDCiv)
there is another thread similar to this,a majority of H-T members,including myself use AGX's. i've had mine for almost 2 years on a slight drop and have no complaints...best $325 i have ever spent
Re: KYB AGX questions (zer0_2_6ixty)
i have agx for about a yr now and they work great. i have a 1.3 inch drop on my civic and it rides smooth over bumps. but if u crank it to full stiff yea its gonna be a hard ride. my car is a daily driver also. im using eibach springs wit my agxs.
Re: KYB AGX questions (vtekstorm)
There's not much adjustability with the AGX's.
See my thread here: https://honda-tech.com/zerothread?id=904362
Koni shock dyno here: http://www.koni-na.com/presentations/civic
Re: KYB AGX questions (Marauder)
i mean no matter what shocks u get ur gonna have a little bumpy ride cause its lowered....but i have agx's on groundcontrols, i just got them liek 2 weeks ago and ilove them, they bounce back nicely from big bumps or dips and they handle so beautifully and i only have them on 2 in teh front 3 in the back, and u can go 4 4, i've yet to try that setting
Daily driver. Just installed rear AGX when I installed GSR rear sway bar about a month ago. Stock springs all around and still have stock struts in the front. I have the rears set at the #2 setting. I'm very happy and am looking forward to getting some on the front. Cornering is much improved but I'm sure the 14 mm. GSR sway bar is helping alot. #2 setting not too stiff for bad roads. Concrete cracks are more noticeable than stock shocks (80,000 miles) but the AGX's handle big bumps much better than the stocks. I have gravel and dirt roads to navigate where pickups define the ruts so will never lower the car.
Re: (BLUE EH3)
I had AGX's on my 240 (with eibach sportlines). They're a great ride, not too stiff at all. I never changed them from 2/2 though. They did begin to blow after a year or so.. they just felt a bit less responsive. Take it for what you will.
Re: (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">i have agx installed and cant wait to ride on em!! but question: whats the best setting when ur car is slammed?</TD></TR></TABLE>
Selling them...
AGX do NOT like to be slammed. That's why your warranty is voided if you go over 1.5" drop or so. Plus, Hondas in general don't like to be slammed. We don't have a lot of suspension travel to begin with so save yourself some money. If you want to ride around slammed, you'll be on the bumpstops anyway so just go get some blown shocks out of the junkyard.
Selling them...
Re: KYB AGX questions (Tommytom83)
I had the KYB's on my car with eibach sportlines and they blew out in two weeks. If you plan on using them on anything other than car shows use a quality strut/shock...like bilstein, koni or tein, then you'll be happy and not have to rebuy em two or three times a year
got the the agx's with ground control sleeves, they work fine, koni yellows would be nicer just so i wouldnt have to keep on worrying about ride height. agx is fine if your not gonna go too low and its easier to adjust in the rear than koni yellows if you carpeting in the back.
The_Honda_Guy
Suspension & Brakes
67
06-12-2009 07:39 PM
