98 JDM ITR 5lug on EG Si - axle Q?
98 JDM ITR 5lug on D series EG - axle Q?
Right my front brakes and bearings are shot, and my rear callipers are pretty fubared, and been offered a great deal a 98 JDM ITR hub swap with rims
From searching i found out that I need the axles too, as the hubs are 36mm I cant afford the motor though, so what i need to know is
Will the 98 JDM ITR O/B joints fit the Dseries axles, ie does the interconnecting bar shaft (between the 2 joints) have the same no of splines as a 32mm. Best thread i found https://honda-tech.com/zerothread?id=425012 but it doesnt say 100% that the JDM ITR outer joints will fit ont a D series axle, anyone know, or prefferebaly done it
I am hoping that since D series and b series hubs will swap, so will the inner joints. And if not, is there any other o/b joint that is the same as the JDM ITR, like CRV's or 98 ludes that will fit onto the d series axles
Or will the 98 JDM 5lug only work if you have a b series
Re: 98 JDM ITR 5lug on D series EG - axle Q? (909rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 909rex »</TD></TR><TR><TD CLASS="quote">yea the d series will fit... a friend of mine has done it and he has a d series motor</TD></TR></TABLE>
Has he got email userneame etc, would be cool if i couold double check, as i did a bit more searching and it looks like a no go according to this thread https://honda-tech.com/zerothread?id=605939 so i keep getting conflicting info
sorry if it sounds doubting, but my car is a daily driver, and am doing the work myself, so if i have the bits i need to be 100% it will fit before i do it
EGeezy
09-25-2015 06:12 PM
IIXtremeHansen
12
06-16-2007 07:49 PM
