brake booster install question(already did a search)
Old 08-08-2004, 04:46 PM
LagunaSecaEG's Avatar
Default brake booster install question(already did a search)
alright this is my GSR brake booster...
http://www.we-todd-did-racing....D.jpg
notice theres a brake line that is on the left side
here is another integra GSR brake booster
http://www.imagestation.com/pi...7.jpg
why does this brake booster have 2 brake lines on one side?when i did my install i found out on the brake booster that i have there is a bigger fitting that does on my left side of my master cylinder....im confused..i am not finished with the install yet tho, i just have the booster on...
LagunaSecaEG is offline
Old 08-08-2004, 04:52 PM
pdiggitydogg's Avatar
master cylinder...not booster
the one unit that has the left side line is probably jdm since it would mount on the other side of the firewall
my jdm itr unit
pdiggitydogg is offline
Old 08-08-2004, 10:58 PM
BatuKing's Avatar
Default Re: (pdiggitydogg)
Could be ABS v.s. NON-ABS or different model year.
BatuKing is offline
Old 08-08-2004, 11:11 PM
bpowa's Avatar
Default Re: brake booster install question(already did a search) (LagunaSecaEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LagunaSecaEG &raquo;</TD></TR><TR><TD CLASS="quote">alright this is my GSR brake booster...
you need to saw off the side on the fitting of your car and with the big integra fitting; (re-use the big fitting)reflare it. pain in the *** but well worth it.. dont saw off too much, just the old flared portion.
bpowa is offline
Old 08-09-2004, 06:43 AM
toEknEEg's Avatar
Default Re: brake booster install question(already did a search) (bpowa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpowa &raquo;</TD></TR><TR><TD CLASS="quote">
you need to saw off the side on the fitting of your car and with the big integra fitting; (re-use the big fitting)reflare it. pain in the *** but well worth it.. dont saw off too much, just the old flared portion.</TD></TR></TABLE>
you say its well worth it, what would be the difference between the GSR MC and the RS MC? it seems to do the same thing right.
toEknEEg is offline
Old 08-09-2004, 11:36 AM
bpowa's Avatar
Default Re: brake booster install question(already did a search) (toEknEEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toEknEEg &raquo;</TD></TR><TR><TD CLASS="quote">
you say its well worth it, what would be the difference between the GSR MC and the RS MC? it seems to do the same thing right.</TD></TR></TABLE>
i got a gsr mc.. cause it was available.. but rs will do the same thing the mc is the same size piston.
only thing is rs you dont have to saw and reflare..
if you got the mushy brake feel with your upgrade,, then hell yeah why not get it to work 100%.. i went without it for a while until, one hot day from school when my pedal went to the floor... 50 bucks is a good investment from an accident....
bpowa is offline
Old 08-11-2004, 07:23 PM
93civicsedan's Avatar
The RS MC is 15/16 non-abs and the GSR 1" abs. If you use the rs mc you have to use a matching non-abs brake booster. If you go with the gsr mc youll need the gsr abs booster. To use the gsr setup you will have to reflare one of the lines. The rs mc bolts up with no problems, that what I have on my eg.
93civicsedan is offline
Old 08-11-2004, 07:25 PM
Uniden
Guest
Posts: n/a
Old 08-11-2004, 07:38 PM
murtnabila's Avatar
Default Re: brake booster install question(already did a search) (Uniden)
If goin in an eg y not just get a 91 civic ex 4-dr master cylinder? Simple fit and not ******* with cutting this bending that using that and flaring wut not.
murtnabila is offline
Old 08-11-2004, 08:23 PM
DelSolSi93's Avatar
Default Re: brake booster install question(already did a search) (murtnabila)
Sorry I was following this thread and this is kind of an ignorant question but does upgrading your brake booster increase breaking performance?
DelSolSi93 is offline
Old 08-11-2004, 08:41 PM
murtnabila's Avatar
Default Re: brake booster install question(already did a search) (DelSolSi93)
It will help with pedal feel and reduce pedal travel needed to engage brakes. By the way not a stupid question. It's something you didn't know and wanted to...called learning my friend.
Old 08-14-2004, 08:25 PM
DelSolSi93's Avatar
Thanks! I wonder if theres a better brake booster I could put in my del sol?
boostedjd
12-05-2018 05:00 AM
graham412
03-24-2011 09:57 PM
uses0ap
09-21-2008 08:19 PM
n00bfasho
07-09-2007 03:33 PM
lollypopking
01-16-2005 09:51 PM
Quick Reply: brake booster install question(already did a search)
  • Ask a Question
Question Title:
Description:
