which shocks should i use?
Old 08-09-2004, 11:36 AM
smokerjoe's Avatar
Default which shocks should i use?
i have a 93 civic hatch and my front shocks (tokico blues) are blown. i am fixing to get a new pair of struts in the front and want to know what the best are to get. i have ground control springs, i'm using my car as a daily driver, and want my car to be as smooth as possible while being low as possible. i've been looking at the koni reds and the koni yellows but am not sure which would be the best. any info would be helpful, thanks in advance.
smokerjoe is offline
Old 08-09-2004, 12:08 PM
Soccerking3000's Avatar
Default Re: which shocks should i use? (smokerjoe)
well i have tokico illuminas and love them, havent had a problem in 3 years, but i am little biased lol
Soccerking3000 is offline
Old 08-09-2004, 02:35 PM
Blk2000si's Avatar
Default Re: which shocks should i use? (Soccerking3000)
how many miles did you put on your tokico blues
Blk2000si is offline
Old 08-09-2004, 02:59 PM
jeffk182's Avatar
I have Tokico Illuminas..had them for 1 year..I love them
jeffk182 is offline
Old 08-09-2004, 03:05 PM
IVI
IVI's Avatar
Default Re: (jeffk182)
ive have the blues for over 2 years and theyre the most comfortable i had
koni yellows would be the best in my opinion.
IVI is offline
Old 08-09-2004, 03:42 PM
Evil_Wizard's Avatar
Default Re: (IVI)
This is only my opinion but I think what you should probably do is go to AutoZone or Pepboys. Autozone has the Bilstein shocks that they can order for like 119.99 each. Which i know is HIGH BUT they have a life time warranty on them. And they dont ask to many questions like if the car is lowered or whatever. And if they wont swap them out all you have to do is call corporate. Pepboys is the same way but they have KYB AGX's for like 129.99 or something. Only reason I am suggesting these is that on a lowered car after a couple of years you will blow out shocks. And everyone knows that lifetime warranties kick ***.
Evil_Wizard is offline
Old 08-09-2004, 03:54 PM
nonsense's Avatar
Default Re: (Evil_Wizard)
Koni Sport
nonsense is offline
Old 08-09-2004, 04:00 PM
smokerjoe's Avatar
Default Re: which shocks should i use? (Sleepy92HB)
i put about 5 miles on them, but they were used. i only drove on them long enough to know they were blown. it's all good though because the rears are still good and i got ground controls with them for $100. i'll probably end up getting the tokico whites unless someone can convince me the koni yellows are worth the extra $100-$150.
Old 08-09-2004, 04:16 PM
vtec69's Avatar
go with the koni yellows
you can adjust the damper on them
vtec69 is offline
Old 08-09-2004, 04:23 PM
smokerjoe's Avatar
Default Re: which shocks should i use? (vtec69)
can't you adjust the tokico illuminas?
Old 08-09-2004, 04:57 PM
locass316's Avatar
illumina adjustable as well. i had them with GC and they kicked ***. Koni yellow still better though
locass316 is offline
Old 08-09-2004, 05:11 PM
Dave421's Avatar
yellows are the best you can get for a honda. infinitely adjustable rather than 4 or 5 settings that someone else thought would be good without knohwing anything about your car. lifetime warranty. easy to get service if you want to revalve them for higher rates (not necessary until you go over 450-500 lbs/in.). i don't knowa anyone who has blown a set on the street. i know only a couple that have blown them on track.
just ask yourself what's better, $150 now or $400 in a year or 2 to replaces the tokicos...
Dave421 is offline
Old 08-09-2004, 05:13 PM
pynikal's Avatar
Default Re: which shocks should i use? (locass316)
i got koni yellows on my ek and i love the heel out of them. its not to hard of a ride but you know the car is lowered. good luck
pynikal is offline
Old 08-09-2004, 05:49 PM
smokerjoe's Avatar
Default Re: which shocks should i use? (Dave421)
you make a good point. i didn't know the koni yellows had a lifetime warranty.
Old 08-09-2004, 06:30 PM
TommyTom83's Avatar
if your looking for an affordable nice shock check out kyb agx's
TommyTom83 is offline
Old 08-09-2004, 06:46 PM
griftbandit's Avatar
I would go with the KYB GR-2 struts for budget or if you have the cash the AGX shocks with custom eibach springs for your preference
griftbandit is offline
Old 08-09-2004, 08:30 PM
dsowers19's Avatar
Default Re: (griftbandit)
I love my tokcio blues
dsowers19 is offline
Old 08-10-2004, 02:27 AM
Allmotorek's Avatar
go for koni yellows
Allmotorek is offline
Old 08-10-2004, 06:11 AM
egisk09
Guest
Posts: n/a
kyb agx struts...best investment ever
Old 08-10-2004, 07:25 AM
jolt-tsp's Avatar
Default Re: (egisk09)
I run the AGX's, they are good. My IRA is my best investment ever though
jolt-tsp is offline
Old 08-10-2004, 08:29 AM
Naturally Aspirated's Avatar
Koni yellow will take care of it man...
Very nice set of shocks...
I used them with ground controls, and when i want comfort, i will just raise the height of GC, then the whole suspension would feel really comfy...
Track days, just drop it low and adjust your dampers, and u're good to go and ride in rails...
Naturally Aspirated is offline
Old 08-10-2004, 08:35 AM
5gcivicsleeper's Avatar
Default Shocks to use
Personally i will never buy anything other than Tein or JIC, I have Tein SS full suspension/coilover setup... 16-way adjustable shocks , but if you dont' want to spend about $950, get AGXs or Koni yellows, i think reds are more for serious autocrossing / roadcoarsing, unless u r into that
5gcivicsleeper is offline
Old 08-10-2004, 08:49 AM
nonsense's Avatar
Default Re: Shocks to use (5gcivicsleeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5gcivicsleeper &raquo;</TD></TR><TR><TD CLASS="quote">Personally i will never buy anything other than Tein or JIC, I have Tein SS full suspension/coilover setup... 16-way adjustable shocks , but if you dont' want to spend about $950, get AGXs or Koni yellows, i think reds are more for serious autocrossing / roadcoarsing, unless u r into that</TD></TR></TABLE>
just for fun, how do you have your SS's adjusted? Have you had the car corner-weighted yet?
nonsense is offline
Old 08-10-2004, 07:30 PM
Dave421's Avatar
and i'm betting you've never owned a set of yellows. you can get off tein's ***** now. i get so damn sick of the "jdm y0!" attitude with honda drivers. for $950, i can get a set of yellows & gc with whatever rates i want & run circles around you with tein's "understeer is fun" spring rates. the ss suck compared to yellows. let's see.....no lifetime warranty, much smaller adjustment range, you have to send them to one of only a couple of u.s. places for revalving after you blow them or get better spring rates...should i go on?
Dave421 is offline
Old 08-10-2004, 07:36 PM
D21X's Avatar
Default Re: Shocks to use (Dave421)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave421 &raquo;</TD></TR><TR><TD CLASS="quote">
and i'm betting you've never owned a set of yellows. you can get off tein's ***** now. i get so damn sick of the "jdm y0!" attitude with honda drivers. for $950, i can get a set of yellows & gc with whatever rates i want & run circles around you with tein's "understeer is fun" spring rates. the ss suck compared to yellows. let's see.....no lifetime warranty, much smaller adjustment range, you have to send them to one of only a couple of u.s. places for revalving after you blow them or get better spring rates...should i go on?</TD></TR></TABLE>
so damn true, koni yellows &gt;&gt;&gt; tein ss's shocks
D21X is offline
nicholasm
Suspension & Brakes
38
09-14-2011 09:18 PM
hawk2828
Suspension & Brakes
01-21-2010 04:45 PM
daewonder.
11-05-2003 03:51 PM
leath213
01-30-2003 09:32 AM
1fastGSR
06-28-2001 05:51 PM
Quick Reply: which shocks should i use?
  • Ask a Question
Question Title:
Description:
