I think my ignition is broke...
Old 08-08-2004, 08:22 PM
liljohnson's Avatar
Default I think my ignition is broke...
So I get off work and I get in my car and put the key in... The key turns about a half of an inch and that's it... It doesn't even turn enough to be able to turn on the radio... My friend and a couple of other people (including a worker at AutoZone) said that it's most likely the ignition. My friend said this was common and it's easy to replace... Should I go ahead and try to replace it?
liljohnson is offline
Old 08-08-2004, 08:36 PM
john666's Avatar
Default Re: I think my ignition is broke... (liljohnson)
is your car key warn a bit ? ? ?
john666 is offline
Old 08-08-2004, 09:05 PM
IVI
IVI's Avatar
Default Re: I think my ignition is broke... (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 &raquo;</TD></TR><TR><TD CLASS="quote">is your car key warn a bit ? ? ? </TD></TR></TABLE>
i would definitly go try another key before i replaced my ignition.
if you dont have a spare goto the dealer with your vin # , reg, title, insurance, and they will cut you a new one given its the same stock ignition the car came with.
IVI is offline
Old 08-08-2004, 10:07 PM
liljohnson's Avatar
Default Re: I think my ignition is broke... (IVI)
No the key is fine I've tried all three that I have...
Old 08-12-2004, 11:34 PM
pArAdOxsqUArE's Avatar
well i'd try to save some money & dissassemble it. & mess with it. if not it's only gonna cost you like $40-60 for a new one but the badd thing is if you car only has one key for all your lock's you'd have to have 2 seperate key's
pArAdOxsqUArE is offline
Old 08-12-2004, 11:48 PM
IVI
IVI's Avatar
Default Re: I think my ignition is broke... (pArAdOxsqUArE)
they can code it for about 80 bucks.
but you dont need the whole ignition. you just need the cylinder that plugs into the ignition. maybe you can find a junk yard that still has that piece intact.
the dealer codes them for you.
or you can use 2 keys like i used to do.
its better in my opinion.
i used to let my car warm up outside my house with 1 key in the ignition then lock all the doors and go inside so i dont freeze, and open the door with the 2nd key.
so it has its benefits.
IVI is offline
rt1976
05-03-2014 05:27 PM
Barf Hat
02-12-2012 06:56 AM
jdmunlimited1
04-03-2010 05:47 PM
d15b7racer
11-21-2005 02:48 PM
EM1_GIL
04-06-2005 05:46 AM
Quick Reply: I think my ignition is broke...
  • Ask a Question
Question Title:
Description:
