Help with CEL 3, map sensor
I just finished swapping out my z6 with the jdm d15b7...everything ran fine for a while and then the CEL came on with a code 3...i tried using a sensor off another d15b7 and my z6...but no luck...all vacuum line seem okay and know don't know what else to do...help!
Re: Help with CEL 3, map sensor (lilobusta)
I am also having map sensor problems mine is toast. on your d15b7 does it go on the intake manifold, or on the firewall? I have a d15 map sensor, from my old engine, ill trade ya for your z6 one. also are you clearing your ecu? under your hood there is a fuse box , pull the 7.5 amp fuse closest to the firewall this will clear your codes
Modified by sonicivic at 10:22 AM 8/9/2004
Re: Help with CEL 3, map sensor (Luserkid)
Luserkid...Nope no boost...thats how i blew my z6
sonicivic...i've tried other d15b7 sensors and still getting the cell and it goes on the manifold
before when i had the map code going off i would reset ecu for 30 seconds, nothing. dont know if it makes a difference but it worked after i unplugged the postive for 15 minutes
