Whinning noise with PE belt! HELP!
Old 08-09-2004, 05:46 AM
Takashi1978's Avatar
Default Whinning noise with PE belt! HELP!
Hi all,
After i change to the PE timing belt i get this whinning noiseor sound everytime i go above 2000rpm.Gets louder as the RPM climbs.
Asked a few "performance" shops and all said PE belts are suppose to make those noise since they are harder than normal belts.
to all who have this belt....is this true?
I have new bearings and water pump.
If i have to take everything out and re-install it,whats the correct torque spec on every screw/bolt/nut when installing? (i'm thinking this is one of the cause for the noise)
BTW this is a B16B motor.
Thks all!
Takashi1978 is offline
Old 08-09-2004, 07:31 AM
Davep's Avatar
Default Re: Whinning noise with PE belt! HELP! (Takashi1978)
Sounds like you might have it to tight.
Davep is offline
Old 08-10-2004, 02:12 AM
Default Re: Whinning noise with PE belt! HELP! (Davep)
How can i be sure?
Which areas should i look into?
willfly
04-01-2013 08:02 AM
Shiznit028
03-26-2009 10:22 PM
mcbasspro
04-02-2006 08:59 PM
Rocks
04-17-2005 10:09 PM
-slow ej-
02-26-2004 09:38 AM
Quick Reply: Whinning noise with PE belt! HELP!
  • Ask a Question
Question Title:
Description:
