cam seals....are they the same?
i need a new cam seal for my gsr motor. its the one next to the distributor, it has a small leak. can i buy a 00 si cam seal and use that on my gsr motor, are they the same?
Re: cam seals....are they the same? (hondaeg8)
they will work fine for you. I have the str and it looks exactlly the same. Put a liquid gasket arond the cam seal just for protection when to come to install it.
Re: cam seals....are they the same? (EG2 SiR)
is it called a cam seal or a cam cap?
i need the one that is next to the distributor. the little plastic black thing.
i went to the dealer and asked for a cam seal and he gave me something that looked kind of like a spark plug gasket deal (the one that goes under the valve cover). he didn't know what i was talking about.
If you are looking for the exhaust seal and want to go oem I think the itr piece is plastic with an o-ring instead of the hard rubber like those found on the b16.
EDIT: I just checked and cross referanced the pn and they are all the same 12513-P72-003
Either they are all that way now or that part is just exclusive to japan because thats where I lived when I bought it.
Re: cam seals....are they the same? (_BEN_)
i thought they were all plastic now and had the o ring. my friend has an itr motor and i saw his "cam seal" and it was the plastic one with an o ring.
i'll probably call the Acura dealership tomorrow and ask them if they have one. i need to know what its called though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 »</TD></TR><TR><TD CLASS="quote">is it called a cam seal or a cam cap? </TD></TR></TABLE>
a cam cap is a metal brace that holds the cams down from the top in the cam journals.
Re: cam seals....are they the same? (Damon)
so its a cam seal or what? the guy at honda couldn't figure out what i was talking about. i wasn't in my hatch, so i couldn't show him my motor.
vlc92189
03-15-2007 05:34 AM
Jonathan_ED3
04-09-2002 07:35 AM
