REBUILD PROBLEM!!
Old 08-08-2004, 06:20 PM
slammedcoupe's Avatar
Default REBUILD PROBLEM!!
Engine was taken out of the car(D16Y8) and air conditioning was removed. Bottom end stock crank, eagle rods, SRP pistons ARP head studs. As for the head just a Comp Cam and re-adjusted the valves, and the rest, Skunk 2 Intake manifold, 520cc MSD injectors with stock fuel rail+regulator. Skunk 2 exhaust cat-back AEM CAI, New wires and plugs 2 degrees colder. Anyways the engine was rebuilt and put back in the car. All connections were hooked back up except for 1 air conditioner plug.
ANYWAYS HERE IS THE PROBLEM, When the engine is started up it is not burning all the fuel, you can smell it out of the exhaust and the cat goes RED HOT!! and it just seems like its not running right. Also the check engine light stays on.
NEED HELP ASAP!!!!
Also am going OBDI chipped with hondata and going turbo.
Old 08-08-2004, 06:34 PM
07's Avatar
Default Re: REBUILD PROBLEM!! (slammedcoupe)
ummm well you do have HUGE injectors running stock injector pulses...................
slammedcoupe
08-13-2004 02:38 PM
slammedcoupe
08-12-2004 09:01 PM
slammedcoupe
08-09-2004 07:01 AM
slammedcoupe
08-08-2004 06:57 PM
Quick Reply: REBUILD PROBLEM!!
