map sensor trouble in ohio
Old 08-09-2004, 06:30 AM
sonicivic's Avatar
Default map sensor trouble in ohio
map sensor failed and fouled all of my plugs. anyone have one? 92 civic EX. was using iridium denso, on turbo motor, am I doing something wrong?
sonicivic is offline
Old 08-09-2004, 07:17 AM
turbotime's Avatar
need....more....info
what is your setup? Engine? Turbo? ECU? Ae you FMIC?
turbotime is offline
Old 08-09-2004, 07:41 AM
sonicivic's Avatar
Default Re: (turbotime)
d16z6 greddy turbo kit, p28 ecu. if map sensor is bad will it foul my plugs?
Old 08-09-2004, 07:53 AM
1992Si's Avatar
Default Re: (sonicivic)
Have you pulled the plugs to look at them? You need to do that.
We were told by NGK to use BKR7E11 I think it was, I have it written down someplace. They cost about $2.00 each. We have an Apexi kit on the 92Si. If you check out http://www.turbod16.com there are post there about it.
1992Si is offline
Old 08-09-2004, 07:57 AM
sonicivic's Avatar
Default Re: (smithby)
I pulled the plugs and they were very black, with carbon build up
oksblue
03-31-2013 03:59 PM
Stevegunit16
10
02-14-2007 07:21 PM
jmeyer99
11-06-2006 07:07 PM
mercury
07-06-2006 05:00 PM
teler86
12-18-2004 10:50 AM
Quick Reply: map sensor trouble in ohio
  • Ask a Question
Question Title:
Description:
