ecu for k20a2 ek civic
i just bought a wrecked '02 rsx type s 6 speed and i need to figure this out b4 i start this swap. i have hasports installation instructions and it says you need the immobilizer removed and from what i hear, you have to have hondata do this for about a grand. i also heard the immobilizer is what makes it so only the original key that came with the car will start the motor so i'm wondering if i can use the acura ignition switch in my ek and not have to mess with my ecu? is that what the immobilizer does?
Unceasing Measure
Re: ecu for k20a2 ek civic (98b16ex)
actually you can just ground the immobilizer function out of the ecu by attaching a ground wire to it. Search about it on clubrsx.com...it's a common thing to do. Also, the hondata reflash isn't only to remove the immobilizer, it's to remove the ECU's search for the different emission controls that are on the RSX-S that probably aren't on your car.
purejdmek9
06-24-2009 10:11 PM
98, civic, ecu, ek, ground, grounding, immobilizer, immobolizer, k20a2, performance, removed, rsx, type
