Header for D16Y8 work on Y7?
I know that the D16Y7 manifold has the cat built into the manifold, but other than that will a header made for D16Y8 fit if I don't use the cat or find a replacement?
Re: Header for D16Y8 work on Y7? (sniggler316)
When I tried it in my HX, which has an exhaust manifold like the y7, it didn't quite reach with a "normal" sized donut gasket.
I ended up getting a used oem cat and an exhaust for an ex.
Re: Header for D16Y8 work on Y7? (Ghetto Civic HX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghetto Civic HX »</TD></TR><TR><TD CLASS="quote">When I tried it in my HX, which has an exhaust manifold like the y7, it didn't quite reach with a "normal" sized donut gasket.
I ended up getting a used oem cat and an exhaust for an ex.</TD></TR></TABLE>
So with a oem y8 header and cat, it bolts up perfectly to a y7? Can I just use a y8 cat with the stock y7 header?
Re: Header for D16Y8 work on Y7? (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW »</TD></TR><TR><TD CLASS="quote">
Can I just use a y8 cat with the stock y7 header?</TD></TR></TABLE>
so you want to put 2 cats on your car???
Re: Header for D16Y8 work on Y7? (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">so you want to put 2 cats on your car??? </TD></TR></TABLE>
is the cat part of the header on the y7? i know it's right under.my cat is bad and o2.
yes on the y7 the cat is built into the header, get an aftermarket header and EX cat and your set, you just need to extend your secondary 02 sensor wires to under the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">yes on the y7 the cat is built into the header, get an aftermarket header and EX cat and your set, you just need to extend your secondary 02 sensor wires to under the car</TD></TR></TABLE>
ic, really dont want to spend any money on this pos motor
i guess i'll try to find a oem y7 one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniggler316 »</TD></TR><TR><TD CLASS="quote">So I don't have to use the full exhaust from an EX, just the cat?</TD></TR></TABLE>
yes
yes
Actually, I found out that the holes on the y8 header don't line up with the studs on a y7 head. Oh well...
shepworldwide
08-06-2006 11:20 AM
jdmjunkieXL
05-01-2006 10:53 PM
