Clutch not engaging..
When i start the car up i can't put the car in any gears while holding on the clutch. There is good pressure on the clutch pedal but it won't go into gears. While the car is off the gears go in perfectly. Any suggestions?
Re: Clutch not engaging.. (Quick_hatch)
Same thing happen to me. In my case flywheel bolts backed out and clutch disk was not making contact with flywheel.
Re: Clutch not engaging.. (schlit)
Sounds like a slave cylinder problem - they can be very temperamental and do screwy things with the clutch engagement and pedal feel. A new one ranges between $80 and $100 from the dealer, but I would try bleeding it first.
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick_hatch »</TD></TR><TR><TD CLASS="quote">i tried bleeding it already twice. It seems like it isn't pushing the fork all the way.</TD></TR></TABLE>
...so ******* replace it. It's like $20 at Advance Auto
Re: Clutch not engaging.. (Archidictus)
did you resurface the flywheel before you installed the clutch? if not then your clutch disc could have gotten contaminated and fried itself
Re: Clutch not engaging.. (bluebird)
its all brand new. there may be a leak near from the clutch slave cylinder. i'm going to try tou se m y friends and see if it works.
