What rotor to use on civic with the ITR calipers???
Im doing the brake swap on my car i had all the stuff last year but i did not order the rotors. I have 94 lude Vtec calipers and pads. I forget what rotors need to be used but u have to re drill them i just need the 56.1mm center bore
Josh
Josh
Re: What rotor to use on civic with the ITR calipers??? (JDMCRX)
what knuckle are you using? i just saw your thread title... then read your original post...
so which one do you have? Prelude calipers or ITR calipers? or are they the same?
Re: What rotor to use on civic with the ITR calipers??? (Gump)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gump »</TD></TR><TR><TD CLASS="quote">92-96 Preude VTEC rotorsis what I used, They have the same diameter hub as a Civic.</TD></TR></TABLE>
Just use TypeR hubs and rotors.
Re: What rotor to use on civic with the ITR calipers??? (TougeSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TougeSiR »</TD></TR><TR><TD CLASS="quote">
Just use TypeR hubs and rotors.</TD></TR></TABLE>then that would be a 5 lug conversion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX »</TD></TR><TR><TD CLASS="quote">I ordered up 94 prelude VTEC rotors there 4 bolt but a 64mm hub size</TD></TR></TABLE>
When you say hub size do you mean the bolt pattern? I think what you mean is that you need a 11" rotor that is 4X100 and what you have is 4X114.3 right?
RC000E
Suspension & Brakes
03-21-2009 11:32 PM
