getting rotors off?
getting rotors off?
I've got everything apart and the rotors are stuck on there pretty good. I tryed whacking the rotor with a hammer a few times, which normally works, but it didnt do anything. The haynes manual talks about using a couple bolts to get the rotors off, what size bolts (thread size) do I need to thread into these holes??.. Also I am suppose to thread these into the 2 holes that aren't the ones that the screws go into correct?
O.G. triple O.G.
Re: getting rotors off? (93CamaroLT1)
any 10mm bolts will work. Instead of a hammer...try a rubber mallet. I'm hoping you have already removed those two rotor screws.
Re: getting rotors off? (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo »</TD></TR><TR><TD CLASS="quote">any 10mm bolts will work. Instead of a hammer...try a rubber mallet. I'm hoping you have already removed those two rotor screws. </TD></TR></TABLE>
the 10mm bolts are too small for the other 2 holes... Am I suppose to put the bolts into the screw holes? I put a couple 2 inch bolts in there and they just never bottomed out.. which is why I figured I was suppose to use the other 2 holes.
dbbyleo
09-21-2008 12:49 PM
TorquelessB16A2
08-14-2008 02:14 PM
ThaSpitefulWun
19
07-12-2004 04:24 PM
