what piston is this?!?!?!? help ASAP!!
help me out i need some really fast opinions!
https://honda-tech.com/zerothread/1655517
Re: what piston is this?!?!?!? help ASAP!! (Spracer03)
Can't really tell, it has much higher commpression then a PR3, it might be a P30 or a CTR piston...but can't really tell...
Re: (Spracer03)
What is the compression ratio? stock GSR shouldn't be a problem at all, with CTR pistons, I've hered different things...mostly that 93 octane has to used to be on the save side!
thats the thing, its a lsvtec.. at tdc the piston sticks out of the hole ever so slightly, raising it even more... oh well the owner said to go ahead n throw it on, ill be taking this car to hookups on moday most likely
Re: (Spracer03)
Check this out, this sould help you abit, this will tell you if you can use it or not good luck with your build: http://www.c-speedracing.com/h...c.php
C_Rock77
24
12-01-2009 03:00 PM
