need help with code 41
i checked all my plugs and wires but im still getting code 41 what could it be? where do i located this plug or whatever it is? thanks
Re: need help with code 41 (kyorishin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kyorishin »</TD></TR><TR><TD CLASS="quote">where would dat be?</TD></TR></TABLE>
on the exhaust manifold
it's right next to the hole where u pull ur dipstick out of, a lil wire going into the heat shield.....personally I'd try replacing it first, narrowband O2 sensors aren't usually that expensive, though I've seen them go up there pretty high...
Disconnect battery, chnage O2 sensor (scerws out, screws in), Re-connect battery..
Good Luck
Good Luck
integracivic94
09-11-2003 12:27 PM
