Built b16a3, now headgasket is leakin oil on the block, PLZ help.
just finished building my motor, the ****** head to block is leakin oil at a slow but steady rate, its because the chilton manual gives the wrong torque spec sequencee (a non criss cross pattern)
So i put 80 miles on the HG, can i reuse it if i spray it with copper, or do you thing retorquing the head would work without even lifting the head fromt he block??
If i reuse it can i torque it more than 72ftlbs to ensure a better seal??? I'm using ARP HEADSTUDS
What should I DO?
Thanks
Michael
Did you have the head checked out? I usually retorque my headstuds after about 100 miles of putting a motor back together, but if its a steady leak, then I'd check out the head and maybe even the block is the machine shop says the head is ok.
Re: (hondafan62269)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondafan62269 »</TD></TR><TR><TD CLASS="quote">Did you have the head checked out? I usually retorque my headstuds after about 100 miles of putting a motor back together, but if its a steady leak, then I'd check out the head and maybe even the block is the machine shop says the head is ok.</TD></TR></TABLE>
if the head or block is warped you could have a prob have it checked out
hybridtech
06-14-2004 01:51 PM
3rdGteg
12
09-29-2003 08:00 PM
