b16 gauge cluster
b16 gauge cluster
i have a 94 ex with a b16 and the tach is incredibly inaccurate. several people said that an itr gauge cluster is the most accurate but i found a b16 cluster for sale out of a 94 crx for sale for much less that a type r one. that would work just fine for accuracy for my engine, correct?
Re: b16 gauge cluster (whiteb16)
expletive. i just saw that it is only kph so disregard the last. any suggestions for a cluster for a b16 that is not from an expensive type r?
All Honda tachs are not accurate as compared to an aftermarket tach. You will always be off a few hundred RPMs with any cluster. However, if you are looking for a tach which has a higher redline without KPH, I would suggest you find a UKDM Civic VTi cluster. What do you mean from a 94 CRX? Like a 94 Del Sol VTEC? Either way, you will need to modify your dash to accomodate the new cluster as well as rewire your cluster harness.
