Cuise control - Electronic vs mecanical versions
New User
Hi guys!
I want to swap in an acura 99 EL (same as civic with few options), but I don't want to loose my cruise control. Apparently, for some reason, when you swap in a EL that has the electronic cruise control, it becomes non-fonctionnal. What are my options? Would there be a rewiring necessary? Convert to the mecanical version of the cruise control (vacuum activated, 4 wires)?
Thanks for any help!
Re: Cuise control - Electronic vs mecanical versions (charjacq)
more than likely will be to much hassle and money for what your gonna get. cruise control stuff isnt cheap. maybe buy a universal system and try that. ive seen some for like 75 bucks. as opposed to the mucho dollars for factory cruise stuff
New User
Re: Cuise control - Electronic vs mecanical versions (postman)
Sure, but I want to understand what makes the factory cruise not work when swapping? What is the ECU sending where that makes it not work?
New User
Re: Cuise control - Electronic vs mecanical versions (mugenpowered)
Anything, I'm swapping a GSR in, but apparently there is something with the ECU communicating with the cruise control box and it will not work when you swap out the ECU.
xkrntamax
Audio / Security / Video
10-24-2007 01:52 PM
ajbucci
11-05-2005 03:07 PM
