2000 b18c5 swap in a 2000 Civic EX
What has to be done and what needs to be bought to swap a b18c5 in a 2000 civic ex coupe? My friend is thinking of doing this because he found a full swap (motor, tranny, ecu, engine harness, axles, motor mounts, shift linkage, etc.) for a good price. Any info on this swap would be highly appreciated. Thanks.
-Chris
-Chris
Re: 2000 b18c5 swap in a 2000 Civic EX (90AccordVTEC)
lets see how fast this guy gets flamed on this forum. if ur new, read the rules and guidelines my friend.
Imperious: Mod of Valor
Re: 2000 b18c5 swap in a 2000 Civic EX (EGdrop6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGdrop6 »</TD></TR><TR><TD CLASS="quote">lets see how fast this guy gets flamed on this forum. if ur new, read the rules and guidelines my friend.</TD></TR></TABLE>
Let's see who's going to be unhelpful and post responses like you.
Try starting here my friend.
https://honda-tech.com/zerothread/878010
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread/878010</TD></TR></TABLE>
another noob owned!
another noob owned!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90AccordVTEC »</TD></TR><TR><TD CLASS="quote">What has to be done and what needs to be bought to swap a b18c5 in a 2000 civic ex coupe? My friend is thinking of doing this because he found a full swap (motor, tranny, ecu, engine harness, axles, motor mounts, shift linkage, etc.) for a good price. Any info on this swap would be highly appreciated. Thanks.
-Chris</TD></TR></TABLE>
you need the 99-00 SI rear L bracket..and 99-00 si driver side mount... the EX harness works fine you just need to extend a few wires.. i dont belive the ITR ecu works for the civic either.. i would do obd1 conversion harness and a chipped obd1 ecu
Re: 2000 b18c5 swap in a 2000 Civic EX (Timmay)
you need 99-00 si mounts and if you can try finding a si harness too or you can extend some wires on yours. the ecu will work but for tuning purposes i would convert and run obd-1
Re: 2000 b18c5 swap in a 2000 Civic EX (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">you need 99-00 si mounts and if you can try finding a si harness too or you can extend some wires on yours. the ecu will work but for tuning purposes i would convert and run obd-1</TD></TR></TABLE>
Use your existing harness, Use 99-00 Si Drivers side mount, 99-00 Si Rear bracket, 99-00 Si Shift linkage, and 99-00 Si Axles. You are able to use the 2000 ITR ecu as well.
Good luck with it.
Good luck with it.
Re: 2000 b18c5 swap in a 2000 Civic EX (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. »</TD></TR><TR><TD CLASS="quote">
Good luck with it.</TD></TR></TABLE>
He can use the integra axles and shift linkage(which he said is incuded in the swap).
Just a little FYI you will have a hard time getting the motor to start using the ECU that comes with that motor since there is a built in engine imobilizer. You would need to use the ECU from like a 98 since they didnt make the ITR in 99. Some people say you can take it to honda and they can fix it for you however i had no luck with this. Good Luck!
http://www.phear7imports.net/trey/6gen/
that should help you with everything you need to know. period!
Re: 2000 b18c5 swap in a 2000 Civic EX (e gee two)
easy as ****
-2000 Si wiring harness
-2000 Si engine post and rear T bracket
-use OBD2B -> OBD1 jumper harness and use p28 chipped ecu
done deal
done deal
ic3pham
04-09-2008 11:41 PM
xtreme412
11-16-2005 03:54 PM
