22mm type r sway bar on an eg
Ok guys I have searched and found out how to install it in an integra. Knowing that the eh hatch and integra have very similar suspensions, I was wondering if I could use the how to for the integra to install my sway bar.....
Also I was wondering if someone could give me a list of all the parts needed to install it. As of now I have the
1. 22mm type r sway bar
2. Bushing that are mounted at the end
3. Gsr end links......(was told that they would work)
I would appreciate all and any help.....
Re: 22mm type r sway bar on an eg (2mansi)
22mm... It's better off you buy buy the ASR 22mm kit. It come with everything you need. Beside it's a good idea to re-inforce the subframe anyways.
you will need the lower control arms from a 93-95 civic 4dr lx ex or the 94-01 integra. they hare the mounting point for the rear sway bar. Also better look into a sub frame brace with that big of a sway bar. You will rip out the sub frame. Look for post about sub-frame failure
Re: 22mm type r sway bar on an eg (kaiba)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">22mm... It's better off you buy buy the ASR 22mm kit. It come with everything you need. Beside it's a good idea to re-inforce the subframe anyways.</TD></TR></TABLE>
Here's instructions on how to install it in an EG with a parts list and part numbers.
http://www.passwordjdm.com/Ins...G.pdf
typeeg
09-26-2003 03:53 PM
iwishiwereajap
24
09-12-2002 02:27 AM
