shift linkage?
shift linkage?
do i use the oem shift linkage if i get a h22 swap into a 96-00 civic hatch?
also can i use any shift linkage if i get a gsr swap into a 96-00 hatch? or does it have to be from a 99-00 si?
Re: shift linkage? (dingy)
to put the h22 in your civic you should use the prelude shift linkage which would require you a make a bigger hole in order to fit the shifter box
and you can use the stock gsr shift linkage
