low voltage reading
low voltage reading
my voltage reading is around 11.7 and when i drive my car, after about 15 minutes the temperature guage on my clusted starts to go up and down from operating temp to high. it stays at operating temp when im on the gas but when its cruising but still in gear, the needle bounces up till i put it in neutral. what could cause a low voltage reading and my temperature guage to act up?
Re: low voltage reading (light2light)
id say QUICKLY get your alternator/ battery checked out!
or your gonna be stranded somewhere with a completly dead battery!
Re: low voltage reading (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elwuudz »</TD></TR><TR><TD CLASS="quote">I am having the same issues
HELP</TD></TR></TABLE>
let me know if you find out what your problem is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">Yes Yes and Yes it can but so can bad grounds</TD></TR></TABLE>
i thought of a bad ground also because i would see the lights on my guage cluster flicker then the guage would move. any idea which grounds i should check?
mycivicswaylow53
21
11-08-2007 08:50 PM
