JDM B16 swap into a EG
I'm doing the wiring for the JDM B16 swap into a EG.
Well JDM are RHD and the engine harness is backward for us.
I was wondering if I can just extend them and plug it right up
to the chassis harness to the ECU?
Or should I just use the stock D15 harness on the B16?
Re: JDM B16 swap into a EG (GSR_hatch936)
2 plugs are different from USDM and JDM.... if your d15 be has Vtec Wire i'd use it. if not, get a obd1 vtec wiring harness out of the 92-95.. you can use the non vtec but you will have to wire it up to your ecu if thats no problem with you.
Re: JDM B16 swap into a EG (dc2doi)
yes 2 plugs will be on opposite side..u can use usdm harness or do what i did is i extended each wire to the driver side with proper wires and connectors to extend them..pm me if u need any advise.
and yes..the ecu harness will plug right in..cause i am running it.i have a jdm b16a sir II swap with original jdm b16a sir II engine harness and the ecu will plug and play
just make sure u get OBD1 b16a swap.
Re: JDM B16 swap into a EG (crazyguy)
i'm in the same place this dude is. i'm swapnig a jdm b16a into my 96 ek. if i use the jdm harness what 2 wires do i need to extend to make it work. thanks
Re: JDM B16 swap into a EG (HONDA300)
ok man ur car is obd1 and lets say u get an obd1 jdm it doesent matter its all plug and play but lets say u dont have the vtec wiring then all u have to do is get the wiring from the silonod and plug directly to ecu and other wire as in the ground plug to the engine
Re: JDM B16 swap into a EG (galaxy2000)
use an engine wire harness from a 92-95 Civic Si and just mod that engine harness. It makes thing so much easier.
Or just mod your D15 engine harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by galaxy2000 »</TD></TR><TR><TD CLASS="quote">jus throw the b16 away, it is slow lol </TD></TR></TABLE>
dood your like 12 years old, go back to 8th grade.
I dont think he was asking if the motor was fast or not.
To the OP you can just use the D15 harness and extend/splice plugs.
GMR*Spork
06-03-2006 11:47 PM
