halp! 92 lx main relay issues
ok so..... I bought a 92 lx not running. I thought the main relay was bad because the car runs when i jump pins 1,3 and 7 on the relay. I just replaced the relay and the car still dont start
Things i checked/replaced:
Main relay
T-stat ground
ECU
all fuses
What would make the main relay do nothing? It dosnt even click at all
Main relay
T-stat ground
ECU
all fuses
Re: halp! 92 lx main relay issues (turbostd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbostd »</TD></TR><TR><TD CLASS="quote">ok so..... I bought a 92 lx not running. I thought the main relay was bad because the car runs when i jump pins 1,3 and 7 on the relay. I just replaced the relay and the car still dont start
Main relay
T-stat ground
ECU
all fuses
What would make the main relay do nothing? It dosnt even click at all</TD></TR></TABLE>
first off when you turn on the car can you hear the pump prime? the relay should be click at this time as well.
Main relay
T-stat ground
ECU
all fuses
Well I drove the car around some with the relay bypassed and noticed a bunch of other electrical glitches. The speedo dont work, alot of the interior accessories also dont work. I gess I will start checking all the fuses tomorrow.
Just2Bar
05-19-2015 03:59 PM
