jdm cluster
jdm cluster
high i am about to receive my jdm eg6 cluster and i have 93 civic hatch and i wanted to know if it was a str8 plug up with the jdm cluster
Re: (BlueIntegraBoy)
What modification does the TCS version require? I just picked up a TCS JDM SiRII cluster and it works fine? Accept the gas/temp guages don't work..
Re: (CapnKrunch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CapnKrunch »</TD></TR><TR><TD CLASS="quote">What modification does the TCS version require? I just picked up a TCS JDM SiRII cluster and it works fine? Accept the gas/temp guages don't work..</TD></TR></TABLE>
Those should work. Make sure the screws behind the gauges are tight. I am talking about the trunk and seatbelt lights are switched.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
Those should work. Make sure the screws behind the gauges are tight. I am talking about the trunk and seatbelt lights are switched.</TD></TR></TABLE>
Ah I see. Well when I got the cluster from my buddy he said it didn't work from him either but I could fix it by taking the electronics from my stock vx cluster's gas/temp guage and putting it on the sir cluster to get it to work. Would that work? Oh and it idles at 20 kp/h.. Is that normal??
Re: (CapnKrunch)
Ah I see. Well when I got the cluster from my buddy he said it didn't work from him either but I could fix it by taking the electronics from my stock vx cluster's gas/temp guage and putting it on the sir cluster to get it to work. Would that work? Oh and it idles at 20 kp/h.. Is that normal??</TD></TR></TABLE>
It's not supposed to idle at any speed. Tighten all your screws.
It's not supposed to idle at any speed. Tighten all your screws.</TD></TR></TABLE>
Ok. I never would have thought tightening the screws would fix the problem. I'll go try it
Re: (CapnKrunch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CapnKrunch »</TD></TR><TR><TD CLASS="quote">I tightened all the screws and plugged it back in. The gas/temp guages still dont work and the speedo still idles at 20 kilometers/hr.
Definitely not right. Have you tried swapping back your old cluster to see if it does the same thing?
Definitely not right. Have you tried swapping back your old cluster to see if it does the same thing?</TD></TR></TABLE>
Yeah, I have.. It did the same thing for my friend that sold it to me too.
Re: (CapnKrunch)
Any ideas of what could fix these problems?? Since the screws didn't work... and none of these problems occur with the stock cluster. Would replacing the electronics behind the temp/gas guages fix the problem? And how about the speedo?
Thanks.
Thanks.
Re: (CapnKrunch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CapnKrunch »</TD></TR><TR><TD CLASS="quote">Heres a pic of the back of the cluster.
Does it look like there are any damages ?</TD></TR></TABLE>
no, they look good to me. chances are the damage is probably internal.
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
no, they look good to me. chances are the damage is probably internal.</TD></TR></TABLE>
Ah ok I see. What would you suspect would be damaged internally to cause these problems?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Do you have another 92-95 Civic cluster with a tach, perhaps a stock VX? If so, swap over the JDM gauges into the other cluster's housing and see if they still work.</TD></TR></TABLE>
Yeah I do have my old stock VX cluster laying around. Is there any DIY on how to do it, or should it be fairly simple swapping the guages? Also wouldn't I loose some of the features the SiR cluster has if I swapped them to the vx housing?
Re: (CapnKrunch)
Yeah I do have my old stock VX cluster laying around. Is there any DIY on how to do it, or should it be fairly simple swapping the guages? Also wouldn't I loose some of the features the SiR cluster has if I swapped them to the vx housing?</TD></TR></TABLE>
You won't lose any features. Remove the cover. Each gauge has 3-4 screws behind it. Straight foward. I'm suggesting this to see if your gauges are working at all and not your housing.
