EG DX door actuators?
Hello, I just installed a Viper 2-way alarm system in my eg civic DX, but it just doesn't feel completed because when I press unlock nothing unlocks, so I bought a universal actuator couldn't make it line up so that it would close/open the lock. So what I would like to clarify is:
Will the actuator from EX, LX fit DX and how many wires does it have coming out of the actuator? I am not going to convert my whole car to power doors I just want driver side to unlock when I press unlock, I will use my own relay.
Thank you.
Thank you.
Re: (rdEJ)
Well, it wouldn't be too much of a problem if I only use one actuator for the driver door and use my own relays to power em. There isn't much to go wrong here
Re: (Niskyspy)
the drivers actuator has 4 wires but you only need 2 of them. the pass only has 2. i did the same in my 94 si, i got actuators and the 3 mounting screws for each from an ex. they bolt right up. then youll need 2 relays or a dei 451m to run em.
CivicSiRracer69
10-31-2003 06:26 AM
