92-95 coupe front end on a 4DR
Well I might be getting a 4 door for cheap and it needs a new front end (hood,lights,fenders and bumper) and my friend just happends to have a front end from a coupe I also think this front end looks better I know I've seen it done befor but what I would like to know is how e-z is it to put this front end on and is there anything I need to do to get it to fit.I don't think it should be that hard but let me know.thanks
Re: 92-95 coupe front end on a 4DR (brian L.)
you will still need 4 door fenders because you will have to cut the fenders in half and weld the front half of a 2/3 dr. fender to the rear half of the 4 door fender.
do it i love the 2/3 door front end on a 4 door
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by forcefedferio »</TD></TR><TR><TD CLASS="quote">you will still need 4 door fenders because you will have to cut the fenders in half and weld the front half of a 2/3 dr. fender to the rear half of the 4 door fender.
do it i love the 2/3 door front end on a 4 door </TD></TR></TABLE>
I don't think you have to cut the fenders to change between the 2 door and 4 door on the 92-95 every thing should bolt right up
Re: 92-95 coupe front end on a 4DR (instructor74)
well if anything I could just try the 4 door ones if they don't work than I'll just get coupe fenders and than get to work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">
I don't think you have to cut the fenders to change between the 2 door and 4 door on the 92-95 every thing should bolt right up</TD></TR></TABLE>
He is right. Use 2dr fenders and use 2dr corner lenses, basically just replace the whole front end (bumper, hood, fenders, cornerlenses, lights) with the 2dr front end. Cutting of the fenders is not needed to make this front end conversion work.
Isnt the 4dr front end longer then the 2dr though? hence why people had cut the 4dr fenders? Could be wrong but always seen people cut the fenders. But would make more sense to just change out the corners and the fenders rather the have to cut and weld **** if it can be prevented.
Re: (lsjon)
The front end is longer on the 4dr, you are correct. That is why when doing this conversion you should to use all 2dr parts. If you use a 4dr hood but use everything else 2dr, the hood will stick out because it is longer. If you use 4dr fenders with 2dr everything else, the fenders will stick out longer than the rest of the front and will not bolt up correctly with the bumper.
bankhead83
09-18-2004 07:41 PM
CarbonCreations
12
10-13-2003 06:05 PM
